You could try this workaround
Not very clean though.
def emp (a:var[]..[])
b = [Imperative]
for (i in a)
if (i==[])
return null;
else
return i;
return b == null ? "xx" : b;
b = [Imperative]
for (i in a)
if (i==[])
return null;
else
return i;
perfect, empty to Null to variable as well
many thanks for the loads of possible solutions, finally I take this like the best option. I modified a script sample of @c.poupin of other post with similar questions to get this solution as well.
the designscript with definition in external code of @Vikram_Subbaiah gets warning telling that “emp” is not defined but it is, although I get result correct but warning and dynamo freezing, not responding for a while, in comparison the python code runs instantly without waiting response, quite tiny in the graph as well.
this kind of answer is not acceptable on a forum where you are offered help, and avoid create multiple topics with same questions
I tried to delete some braces but the code block gets a red warning, expecting the brace removed, I am not familiar writting code as this type, many thanks for your solution, it works well.
If you want to learn DesignScript, there is lots to download.
DesignScriptDocumentation.pdf (705.5 KB)
designscript-final.pdf (1.5 MB)
DesignScriptGuideV2.1.pdf (343.2 KB)
