I want to get a list of the all the schedules in my model. However there is no way to schedule schedules.
Are there packages or modules for Dynamo that can export a list of the schedules in a model?
It would be something like Get.Schedule.by.Name then export that.
That kind of process doesn’t seem to be available.
Is there a way to identify the element ID of the schedule in the model to get their names?
hi @thakopian
you can use these nodes from archi lab package
That’s a good start.
I tried it and got a list but not the names just element IDs:
Is there a way to translate the element IDs into names of the schedules?
I would like to get a list like in the Schedule/Quantities in the Project Browser.
you can get “View Name” Parameter
I see in your example the ScheduleView type has a name already.
My version just lists the ViewSchedule and the element ID. Is that fundamentally different?
When I use the Element.GetParameterValueByName there is no result.
Is the View Type reporting the same information between these examples?
You need to enable the preview of the Element.GetParameterValueByName, or wire in a watch node.
I recommend you run though the Dynamo Primer to avoid significant headaches. Don’t skip any exercise no matter how irrelevant or trivial it may seem.
http://dynamoprimer.com/en/
Thanks for the heads up. It’s getting late.
I got a list now.
I have a lot of elements appearing as “Revision Schedule”
Would it make sense to use a List.FilterbyBoolMask module with a code block “Revision Schedule” to remove those values?
Thanks.
That’s how I would do it.
You can also use the Springs.Sheet.Views+ node which is in the Springs package instead. Conveniently it has the filter already built in.
