List.Map to Create Points on List of Surfaces
I’m trying to create a script that will generate a rectangular grid of points within a Revit Family Type that is a rectangle of model lines. Then, place a component on each of the points created. I have achieved this for a single instance of the family type but I want the script to generate the points for all instances of the family type. I thought list.map would be the way to run the function through the list but I cannot get it working properly. I removed the custom families and revised the code to use surfaces so someone else can run the code. Any suggestions are appreciated. Thanks.
Dynmamo File: Seating-Areas_Loop-Node_TEST.dyn (32.2 KB)
Based on the thread below I learned list.map only allows for one function (node) to be executed on a list. Below are screen shots of an offset working though a list.map, but not an offset and rotate. I’m going to look into a design script solution. Perhaps I can write all this as a function and execute the function on a list.
http://dynamobim.org/forums/topic/loop-more-than-one-function-through-a-list/
You could accomplish what you want using a custom node and connect this to the f(x), with the input being “surface”
If you require multiple input the “List.Combine” node can be used in the same manér as “List.Map”.
Thanks Jonathan. I’ll give that a try and post my results.
It worked! I read through the Dynamo Primer on custom nodes. Then took the set of nodes I created to be the function and created a custom node from it. I then added the inputs and outputs to the custom node and viola, points on a list of surfaces that are relative to each surface’s geometry.
Thanks Jonathan!
You’re very welcome, if a comment solved your problem mark it as the solution and maybe leave a like here and there :slight_smile:
Done and done. I’ll post the final script that shows how I’m using this to populate arrays of tables/chairs or benches on multiple areas on a site plan. My firm is working on a series of shipping container parks where this will help expedite the site design.
Here is my working version. it populates picnic bench or table/chair seating families within a simple rectangle family based on the family type. This is my first go at Dynamo and visual programming. It’s a little different than AutoCAD scripting. Thanks to all in the forum for your help, either directly or through your postings.
