I want to convert the list line to polycurve. but the input is list so I can’t convert the line to polycurve.
So, finally I want to change all line element to polycurve.
How can I change…?
@hojukys , hi
your list is merged by differend linetypes. Try sortByFunction access your lines via ItemAtIndex than you can make out of Lines → polycurves!
KR
Andreas
Yeah. I can use either Roombounderies. My final aim is to deconstruct polycurves to points and then select 4points in Revit to make retangle surfaces to divide each zone (like space planning).
Is it possible…?
import sys
clr.AddReference("RevitAPI")
rooms = []
for i in IN[0]:
rooms.append(UnwrapElement(i))
curves = []
opt = SpatialElementBoundaryOptions()
for room in rooms:
if room.Area > 0: # Make sure it has positive Area, i.e is placed
rvBoundary = room.GetBoundarySegments(opt) # Get room boundary
dsBoundary = [] # A Dynamo list to hold the boundary per room, remember it can be complex, with holes
for rvLoop in rvBoundary: # For each loop in the room boundary
dsLoop = [] # A list to hold each room's loop
for rvPiece in rvLoop: # Retrieve each segment of the loop
dsPiece = Revit.GeometryConversion.RevitToProtoCurve.ToProtoType(rvPiece.GetCurve(),True) # Read the segment as Curve and convert to Dynamo geometry
dsLoop.append(dsPiece) # Add the piece to the Dynamo Loop
dsBoundary.append(dsLoop) # Add the Dynamo Loop to the Dynamo Boundary
curves.append(dsBoundary) # Add the Dynamo Boundary per room to the Curves list
OUT = curves
so i copy/pasted some stuff it works in my example
If you’re actually doing space planning, I personally prefer using a surface for the totality of the room, and subdividing it into ‘cells’ via isocurves. Found it to be a bit more consistent for irregular room shapes which never come up at first, but break everything the first time they do.
A error is not exact…
hahaha that looks funny i think it means something like “…unexpected” @hojukys
