I’m trying to search through a list of views for any number of legends, then identify the sheets on which each legend appears. List.LaceLongest gets me the desired result when I feed it only one view. If I feed it more than one it overwrites the list, rather than producing two sublists, each with the boolean result for each view. I’ve tried (not shown) running list.LaceLongest through a list.map (errors) and repeating the full view list before running it (boolean is done at the sheet level, rather than the view level). In the end I want to be able to identify all the sheets each legend view is on.
Thanks. It works for me in an empty file, copying what you’ve done, however as soon as I try setting it to @L1 it generates an unhandled exception (specified cast not valid). I’m not sure what might be causing the issue in my script.
Can you show what your graph looks like now?
