Any node can contains every item in the list?
Similar like that but the result compare every item not the whole list
Hi Hou,
My first thought was to use List.Map, but the “Contains” node seems to be able to check only lists. So you could either make sure that each value is a list(like shown on the left) or you could try a different node( “==” works great if you’re comparing numbers or strings). If you’re going to use the boolean list to extract the value, maybe “IndexOf” in combination with “List.GetItemAtIndex” might be a faster approach.
What is your end goal?
Thanks Dimitar Venkov
i was try to filter the elements by parameter value
for example i want select all walls elements Room Bounding=Yes
If you want to filter, use a filter:
