I tried querring the level from some conduit and pipe and the level.name node is returning the type name. Not the level name. Is this a bug? Also, I am trying to remove empty slots from my created lists, but the list. clean node seems to be doing nothing at all, in the dynamo dictionary it says it is supposed to remove empty values. Is this a bug as well?
So I tried to create my own work around by eliminating the nulls from the beginning, by checkin to see if the parameter exists, but I am also getting strange values from parameter.hasvalue nodes as well. Please advise.
The Level.Name node expects a leve as an input. You’re giving it not levels so it is giving you not level names.
Try a code block as follows:
A.GetParameterValueByName("Level").Name
It may throw an error but that shouldn’t actually get anything wrong, more an under the hood thing as best I can tell (the level name node as a stand alone does the same). The Element.Name(Universal) node from clockwork doesn’t throw the error but gets the same results for me, so if you want to keep the graph error free omit the .Name portion of the codeblock and use the clockwork node.
Thanks Jacob! any advise on the list.clean node?
not sure I understand what is going on in your photo. You mean that I am only supposed to use this code block?
I dont understand what the one on the left does. But the one on the right makes sense to me.
You can use either the code block on the upper half or the nodes on the lower half. Whichever method you are more comfortable with.
Your nodes are unreadable
ah! Apologies! I’ll upload the dyn on my break for everyone to reference.
Screenshot with text. Wish I knew why that had happened.
Dyn:
List.Clean and Level.Name Nodes Example.dyn (16.8 KB)
