Linked Room boundaries being bounded by linked elements
I’m collecting the rooms from a linked model, then trying to get the room boundaries to find points in rooms. The Crumple Room Boundary node is able to provide the boundaries from linked models, although there seems to be an issue where if the bounding element of a room comes from a linked model then the API isn’t able to create the complete boundary and I’m left with thousands of elements. Snip below showing the output of all the boundaries from a level.
I do not want to create the rooms myself as there’s thousands of rooms, and the architect has said they will get the room bounding correct so it seems a bit pointless to recreate them if they already exist which is also more of a ‘BIM’ workflow to me.
This appears to be an API limitation for Revit 2024 (depending on how accurate this chatbot response this), is there a potential workaround as visually on the floor plan I can see the whole room boundary of the room element, I’m not sure how to read the API docs updates either to see if this has been fixed in newer versions.
I would say it isn’t accurate. Just about anything is possible, but the question is how to go about it, and how fast the automation will run.
The best path forward will require knowing your intent though. is your goal in doing this? Your original statement of “to find points in rooms” is a bit too vague to know what you’re after, otherwise just pulling the room’s location point would do the trick.
At its most basic level the script takes the Crumple ‘Element.Centroid’ node for the elements then transforms the location depending on it’s orientation (downwards if it’s ceiling mounted or located in the ceiling void, forwards if it’s wall mounted, etc) so that the elements that sit on the fringe of the room are moved ‘inside’ the room.
This is so that regardless of the method (intersect solid, point in room, raybounce surface) they should be more accurate instead of overlapping with room boundaries.
Where the outcome of the script is to find what room an element is in for the clients assets register and update a parameter.
Speed is somewhat important, but if it’s necessary to run it on one level at a time in order to get accuracy in room bounding that trade off is acceptable.
Why don’t you get the Linkelement.Solids to get the geometry of rooms? I understand, sometimes it fails, but for 90 % of rooms should be good. Then you can check if the element is inside of the room by measuring the distance from centroids of elements to solids of rooms.
Hello, did you try using the Finish Boundary node?
I don’t recommend centroid in any circumstance as the outcome is too easy to skew to something incorrect. Ideally I would recommend using the family instance’s room location point. Ensuring that on in all the family documents is both a best practice and likely the easiest path forward as it’s a one time event per type instead of once for all instances. For multi-location types (doors, windows) you will have to decide if you want to use the to room or from room point though.
I did try this node and for the same rooms that had issues with room bounding it wouldn’t create the solid.
Do you mean the room calculation point? The elements I’m collecting are all MEP elements, so some categories don’t have that option.
I also prefer the element centroid as I find it a bit more ‘stable’ than the element.location node, what are you concerns about the centroid accuracy?
I tried this and did a comparison against the room boundaries, and the room boundaries collected more boundaries for every room than the finish boundary.
Although the rooms the finish boundary collected all seem to be ‘complete’ rooms which is better for processing if the rooms are bounded entirely within the linked model, while if you look at the preview, the room boundary collection also collected as many boundaries as it could but still ignores any room bounding from a linked element.
The edge case of L shaped objects putting centroid in locations which don’t report a useful location is too frequent. The result of which is significant exception handling which slows things down and you still get a lot of false positives. Enabling location point and reporting rooms that way solves the issue and runs faster as there is no need to pull the geometry of the family instances to get the centroid.
For the object types which can’t have a room calculation point turned on, the location is the next best solution. If the location is a curve type take the curve geometry and pull the center point; if it is a point then just take the point. From there pull the points to an elevation just above the associated level by adjusting the Z component (pntCheck = Point.ByCoordinates(pnt.X, pnt.Y, lvl.Elevation + 1); and get the room at that point using the room at point method.
I’ll update the script to use the location point, I’ve processed the line based families before so that should be fine.
I have seen a few nodes that can take points and rooms, but the internal origin of the linked model is wrong so I’m not sure if these nodes automatically do the transform since I’m inputting linked elements (not rooms from the MEP model), although I guess it’ll be obvious if it doesn’t do the transform because there will be no results.
Instead of working with linked rooms, why not work directly with spaces ? (a process generally applied to MEP models)
Totally agree I could use spaces, but it’s going to take 10-20 times the effort/time to maintain 10,000+ spaces on this project when the architect already has a requirement to deliver bounded rooms so they’ve done that process for me.
I’m very hesitant to use any rooms or spaces as the models are already big enough, if I was to copy spaces in they’d push the file size over to where I’d need to split the models down further.
As a workaround to that if I create the spaces in a dummy model then link in the MEP models to find linked elements in local rooms/spaces, it should work but that’s on the assumption that they get all created perfectly without me having to review the space bounding and then raise the spaces up to be slab to slab to capture elements in the ceiling void.
Spaces in theory are the solution but why replicate something the architect already created, as this process is simply for the asset requirements (no design parameters required) so it wouldn’t even be necessary to create spaces but also use rooms as there’s more dynamo nodes for finding elements.
Do you have a sample model (not the actual ones but ones which reproduce the conditions) for people to help test on?
Stuff like generating the 10,000 spaces (or even 10,000,000 spaces) to do the coordination and then removing them isn’t a big lift.
MEP-Link A.rvt (1.4 MB)
I’ve recreated the scenario where the MEP model has Arch-A and Arch-B as model links where the rooms in Arch-A are bounded by Arch-B, I’ll make a simpler version of my script as well for how I had been finding the points in rooms.
Arch-Link A.rvt (504 KB)
Arch-Link B.rvt (588 KB)
@RDM
it’s quite a long thread and I’m not exactly sure what the goal is.
Seemed to start off with this
but now is more like how to create the rooms (or spaces) in the first place ??
Distilling it down, is the issue this ?:
  • you’ve got a number of points
  • you’ve got a number of polygons (such as rooms)
  • you want to work out which polygon each point is in, then update the attributes of the point with the polygon attrributes- such as name or mark
Your summary is correct, I want to collect the Room Name & Number to put into a shared parameter.
I’m trying to avoid at all costs creating the spaces (or rooms) as I while it’s possible to bulk create these also with dynamo I will likely end up with rooms that have bounding issues which will be hard to spot across thousands of views.
I’ve uploaded the scenario models to try come up with a workaround for the room bounding from linked models, I’d even rather work in an offline version of the architects model to put in room separators than recreate spaces since I know they have their model linking bounding settings already correct.
I’ve simplified the script a bit which shows the behavior with linked element bounding, and my current workaround using the element location closest to whatever room boundary lines that are in the Arch-A model, it’s been updated to use the element location instead of the centroid.
The Autodesk electrical fixture family being hosted makes it hard to move the location of the point ‘inwards’ to the room but in this scenario it still works.
Elements in Linked Rooms - simple.dyn (3.3 MB)
I see what you mean.
Part of this problem is that the collectors for rooms from linked models do not get complete boundaries- as you say, bits of geometry are missing.
I’ve always thought the Revit ‘‘çopy monitor’’ tool should work with rooms. In your case, you would copy monitor all the rooms from the architects into your MEP model. This would eliminate the problem you are having.
You won’t like this answer
but sometimes it is easier to break the problem down into smaller ones and deal with them separately.
In this case, part of it is outside Dynamo. It should be possible fully within Dynamo- but maybe too difficult…
This is how I would do it- using your data:
  1. Export all the room geometry from the architects model into a simple format- just room number or ID and polygon vertices. Easy in Dynamo- refer
    room_geometry.csv.txt (563 Bytes) So room 1 has 6 points in a specific order
  2. Export the element locations (also easy in Dynamo)
    mechnical_equip.csv.txt (146 Bytes) So element 2748 has x&y coordinates on the second row
  3. Do a spatial lookup of which room elements are within. I added a dummy element 9999 outside of any rooms. Refer
    mechanical equipment room lookup.csv.txt (54 Bytes) So element 4861 is in room 3. Element 9999 isn’t in any room
  4. Update the element parameters with this data
This video shows step 3 in a graphical form- but it could probably be done programatically
Andrew
