I’m having trouble in getting location for the linked file’s elements in here you can see i imported all the linked file with pipes & had to sync with my model but after moving my linked file the dynamo do not get the new location of elements tried to restart revit & dynamo run the script again but facing same problem, here is the dynamo & the revit files
Pipe.rvt (7.0 MB)
Beams.rvt (7.1 MB)
1.0 Place Sleeves.dyn (74.4 KB)
Yes if you do so then the model and the link dont share origin, try with some coordinate transform, or try set the project up so all share origin.
