Hey all!
I’ve a question about the possibility to add a batch of models in ACC due to the huge number of links that will be inserted rather than insert them manually.
As i tried to automate this by dynamo but the it seems like the API doesn’t support the Cloud-Based-Data. So is there any solution ?
Thanks in advance.
In your case, let’s consider research Design Automation from Autodesk Platform Services
@Muhammed.ElSaid
When you want to use it, you may be interested in this
Its a bootcamp about the aps from Autodesk
Hello Gavin,
i would love your help, appreciated.
but the case of mine is that i have a bridged models from other ACC Hub so that i have to take direct link from \Autodesk Docs and so on, i can’t upload linked models direct in each folder, but i will look up these solutions in APS for more info.
Thanks again.
Thanks for contributing, Appreciated
it would be great, thanks a lot
