hi all,
did anyone come up with a solution to batch link/reload models in ACC?
In the past I could use any script or plugin in the BIM360 platform, but since they created ACC, it seems like the solutions are not working anymore.
Any ideas?
Cheers,
hi all,
Any ideas?
Cheers,
I have the same question. I found a graph used for repathing links, but it doesn’t work for models in ACC. It doesn’t seem to like the forward slash in the cloud location path.
Autodesk Docs://xxxx/xxxx/xxxxx
Doc’s paths are not file paths, but web addresses; you’re going to have to fetch the cloud model path to repath to an ACC model.
hi jacob,
my initial query was about the Bakery package from Luke Johnson… I was wondering if there’s any update on the ACC (since i know that the web API changed for ACC compared to BIM360).
Or did you tackle the problem in a different way?
(https://github.com/LukeyJohnson/BakeryForDynamo/tree/master/dyn)
No idea how Bakery did it, but directly linking to the local path is a bad idea (even for BIM360 projects) as of 2023 product line.
You’ll want to get a cloud model path, which is usually best via Forge.
Is there a script to view it in Dynamo, or shall it be interrogated in Forge?
Do you have any reference/link to it?
Dynamo can be used to call a forge API to get what you need, however I cannot share such a graph as it is proprietary to the company I was working with.
