Create a File and Link Several Electrical models
Use Dynamo to Export Data from all the linked files into one Excel Sheet
I need to Modify the Excel Sheet and Import the Information Back to the Revit Models.
I know that we can’t write to linked files, so the intention is to open each individual model and import the information relevant to each model from the excel file.
Thank you. I have already done the Dynamo but i have several issues:
If i import an electrical equipment on Revit, I can run the Dynamo and am getting all my result on an excel but when i link an IFC or Revit file to a new project, the excel is empty.
I want to modify the Excel and important it to the revit model.
If you have a script and have problems with it, please show us the script. Right now you are only telling us what you want and none of are willing to do all the work for you for free.
If you want to push data back to Revit, then i recommend to also get the unique id (uuid) of every element. With this id you can write data back to revit (rows with data and id need to stay together).
