Link 3ds Max in Revit
How to Link 3ds Max in Revit Using Dynamo?
@nakhlehkhaled99 , hi
try this here:
The common format between 3DSMax and Revit is the DWG (addition of the OBJ format in Revit 2023). This kind of workflow is therefore not easy if you want to reconstitute 3DSMax materials in Revit and recreate properties.
Thanks!
Will , but I just want to make it easier to do organic geometry in 3DMax, and complete the BIM details in Revit.
Does that work?
If you only want the geometry in Revit, it should work.
It may be relevant to go through Revit families with the DWGs imported into them.
