We all recognize this node:
My question to you is if any of you know if there is an equivalent function in the Revit API.
Or possibly how to achieve the same result but in a different way.
I have searched but can not find a method that replaces the ByStartPointDirectionLength node.
Best regards,
Mikael
You could create the line with that node, then convert the line that is created into a revit line?
An example
import sys
#import Revit API
clr.AddReference('RevitAPI')
def lineDB_ByStartPointDirectionLength(pta, vector, length):
vector = vector.Normalize() * length
return DB.Line.CreateBound(pta, pta + vector)
startPoint = XYZ(1,1,1)
vector = XYZ(1,3,0)
length = 3
line = lineDB_ByStartPointDirectionLength(startPoint, vector, length)
OUT = line, line.ToProtoType()
Thank you @c.poupin !
That was the solution I was looking for
Best regards,
Mikael Zeylon
