Library not showing
Can’t get Camber to show up in Dynamo. I’m obviously new, but the library tab isn’t showing up. Please help
Can you post a screenshot? Also which version of Dynamo and which version of Camber?
And which version of Dynamo? A screenshot of your library expanded out so we understand what you aren’t seeing would help.
Best guess is that you’re using an old (2024 or prior) version of Civil 3D, and version 5.0 and up of Camber will only work in 2025.
Using C3D2025 and it’s installed version of Dynamo. That’s my issue, there is no library to expand out.
Can you send a screenshot of your main Dynamo screen after opening a dyn? This almost certainly isn’t a Camber thing, but a customization you’ve installed.
I think I figured it out. Like I said, I’m completely new. I was expecting Camber to be ready to run routines, but it’s apparently additional scripts for creating new graphs. Thanks for your help Jacob
