Hey there!
I’m trying to set the view direction parameter on a legend component, but I’m running into some issues.
Hey there!
Works for me
Also when doing it your way.
What type of Elements do you try to change?
For Walls you have Floor Plans (-8) and Sections (-5) and
for Doors you have Floor Plans (-8) and Front (-7) and Back (-6).
NB
Not all Legend Components get / have that Parameter. In example Detail Items.
This problem is only in version 2023.0. It works in other versions.
I found a Python script on the Autodesk website tha is suitable for this problem. I tried it and it works
I tried it in Revit 2023 and it worked.
The screenshots came from Revit 2023 + Dynamo 2.16.
Do you mind linking to that webpage instead of screenshots.
If someone comes accross this thread in future that will help them a lot more.
Considering this issue only exists in Revit 2023.0, and that build has a known security vulnerability where someone could infect your system/network by importing an infected .skp file into an RVT project, the guidance should be to update to a secure build yesterday.
https://www.autodesk.com/trust/security-advisories/adsk-sa-2023-0002
