Left, right ups and down references for Dimension
Hello dears,
i want to make a dimension for all Structures columns like this
dim-1
the problem is how can i select the left or right references or up & down, to make the dimension
i have tried the Genius Luci nodes but it give nulls
Any ideas ?
Hi @khuzaimah.ElecEng,
This only works if the references are defined in the family.
See if this helps…
Apologies for the mess, I’m working at speed :slight_smile: Hopefully you can optimise and adapt it…
If the columns are all rectangular then that will help… You know that you will (almost) always want faces 0 & 2 and 1 & 3 for your references etc.
Alban has a Dimension By References node which I would use…
DimColumn.dyn (29.0 KB)
I remember a topic like this before. I suggest you take a look.
Automatic Beam Dimension - #4 by Durmus_Cesur
thanks @Alban_de_Chasteigner ,
that is helpful but not in my case unfortunately , since i cant change family parameter
really appreciated
thanks @Mark.Ackerley,
that is what i really need, i have modify the script for multi dimension and it is worked perfectly
