I’d like to fire up Autocad after a dwg export with Dynamo and open up the exported file. However I couldn’t manage to append file name after acad.exe correctly and it won’t open up the file. Can you take a quick look I think I’m lost in the simple syntax somewhere. Below simple code warns as it can not find specified file…
from System.Diagnostics import Process
command = "C:\Program Files\Autodesk\AutoCAD 2017\acad.exe " + “D:\a.dwg”
proc = Process()
proc.StartInfo.FileName = command
proc.Start()
OUT = command
