Latest version for Revit 2015
where can i find the last version of dynamo that will work with Revit 2015? When I try to add packages, they were all created with a “future version”. I am trying to center rooms and tags.
Thank you.
nevermind…found the previous builds page.
Full info on which dynamo version is supported to which revit version can be found here.
http://dynamoprimer.com/en/08_Dynamo-for-Revit/8-1_The-Revit-Connection.html
got it but had to do a workaround to get to the site. couldn’t go right to the site from your link.
Thank you.
If @Brendan_Cassidy’s comment solved your problem please mark it as solution (and maybe give him a like).
(Also the highest version is 1.2.1 as far as I know).
I have multiple versions of Revit. seems to be an issue with different versions of dynamo installed.
i.e. I didnt see 1.2.1 for 2015 loaded while I had new versions installed for Revit 2018/19.
is there a way to have all installed? without issues?
