Hello everyone
How can i draw curve for Stirrups by right way
I mean like this photo
YA and thx for your answer
i do it by another way
but i find it difficult to make longitudinal bars.
You are Welcome.
Kinldy, Explain in detail what problem you are facing in longitudinal bars and post the workings you have tried.
Translated by moderator. See below the line for original post.
Hello friend, thank you for your contribution, but in revit 2021 I get an error, it seems to me that the writing of the code to join the lines, how could I solve it or do you know if there is a node to replace that code, thank you for your response.
Original Post Below
Hola amigo gracias por tu aporte, pero en revit 2021 me sale un error, me parece que la escritura del código de unir las líneas, como podría solucionarlo o sabes si hay nodo para remplazar ese código, gracias por tu respuesta.
I join Mahmoudelsayedsayed1’s query, I am also trying to divide the surfaces of the L and T columns to generate points and elevate them to create the vertical lines, I used this method but I have not succeeded:
https://forum.dynamobim.com/t/dynamo-create-multiple-surfaces-from-grid/68829
Original Post Below
Me uno a la consulta de Mahmoudelsayedsayed1, tambien estoy intentando dividir las superficies de las columnas L y T para generar puntos y elevarlos para crear las líneas verticales, use este metodo pero no lo he logrado:
Translsted by moderator. See below the line for original post
Surface division image:
Original Post Below
Imagen de división de superficies:
@JOSECERVE the official forum language is English. This is a requirement to make search work.
Please translate all future posts, leaving any native language posts below and separate, as I am doing in the edits to your last three posts.
Hello, okay, sorry, I’m new here.
