Hi everyone!
Can you help me to get parameter values from BuiltIn Parameters in PYTHON. I know how to get Shared Parameters only…
clr.AddReference("RevitAPI")
collector = FilteredElementCollector(doc)
element = collector.OfCategory(BuiltInCategory.OST_Casework).ToElements()
out = []
for i in element:
for param in i.Parameters:
if param.IsShared and param.Definition.Name == 'CATEGORY':
paramValue = i.get_Parameter(param.GUID)
out.append(paramValue.AsString())
OUT = out
Use this property
IsShared
[EDIT]
Hi c.poupin,
Would you mind providing me with an example using the above code?
Cheers,
Oops, I answered too quickly
an example to get only BuittInParameter(s)
element = UnwrapElement(IN[0])
myInternalParameters = []
for param in element.Parameters:
paradef = param.Definition
if not param.IsShared and isinstance(paradef, InternalDefinition):
if paradef.BuiltInParameter != BuiltInParameter.INVALID:
myInternalParameters.append([param.Definition.Name, paradef.BuiltInParameter, param])
OUT = myInternalParameters
Hi @c.poupin
Thanks for that!
Probably a simple question. I was after the values. Is it possible to add the parameter value within your output list?
Also, could it be applied to multiple elements?
Thank you!
Hi @c.poupin
I think I found a way to get the element value:
elementname = element.get_Parameter(BuiltInParameter.KEYNOTE_PARAM)
parameterstoragetype = elementname.StorageType
paramvalue = elementname.AsString()
Can you please help to get a list of all element values?
OUT = elementname, paramvalue, parameterstoragetype
thanks
here an example
toList = lambda x : x if hasattr(x, '__iter__') else [x]
lstelems = toList(UnwrapElement(IN[0]))
for element in lstelems:
if paradef.BuiltInParameter == BuiltInParameter.KEYNOTE_PARAM :
myInternalParameters.append([param.Definition.Name, paramvalue, parameterstoragetype])
Merci beaucoup @c.poupin!
Cela a bien fonctionné !
Hi @c.poupin
Hopefully quick question. If the parameter is an instance Built In parameter (i.e: Room number, level, etc…) how would you approach it?
Thanks in advance!
Here an example
# get Parameter Type
param_type = element_type.get_Parameter(BuiltInParameter.MY_BUILTIN_NAME)
# get Parameter Instance
param_instance = element_instance.get_Parameter(BuiltInParameter.MY_BUILTIN_NAME)
