Hi all,
I am trying to get the values of one type shared parameter from multiple elements. But I am doing something wrong.
It seems to be a problem with the lookup.
What am I doing wrong?
Or is there any other way of doing it without lookup?
clr.AddReference("RevitAPI")
elements = UnwrapElement(IN[0])
values = []
for element in elements:
value = elements.LookupParameter('Code').AsString()
values.append(value)
OUT = values
Hi @aafonsoBYKA8,
You made a typo.
It should be element and not elements.
value = element.LookupParameter("Code").AsString()
Maybe :
value = element.LookupParameter("Code").AsValueString()
It depends of your type of parameter.
Do you obtain the values with the Element.GetParameterValueByName node ?
So it is a type parameter not a instance parameter :
clr.AddReference('RevitAPI')
values = []
value = doc.GetElement(element.GetTypeId()).LookupParameter('Code').AsString()
OUT = values
