Hi, I am having trouble getting this script to overwrite the data from Excel back to Revit Key Schedule. I am using the “Key Schedule Node”
It will write the data its the revit schedule is empty, But If I delete the schedule from revit, which it will lose the key that is assign to each door. So I dont want that…
Thanks in advance!
Dynamo Script File
Excel Data
Hi @boey1219 , welcome.
I had the same issue.
There is a workflow.
- Copy the Keyname to a dedicated parameter.
- Delete all the lines in the Key schedule (not the schedule itself)
3.Re-import the values of the Key schedule.
4.Using a dictionary, assign the Keynames again to the elements, using the dedicated parameter as your identifier.
Element.GetParamtervalueByName for Key schedules - Dynamo (dynamobim.com)
The graph is in the link.
Kind regards,
Willem
