How can I write a code that can automatically join the walls in the same row in both lists? or another suggestion?
You’ll need the JoinGeometryUtils from the Revit api.
JoinGeometryUtils Class (revitapidocs.com)
I meant that in this field can I merge walls with the same sequence numbers in both lists at once?
Thanks it works now. @leonard.moelders
OK, if you could provide better information in detail, then we can provide better answers.
Like:
