Hi everyone.
I write a flow of create Generic Model by Dynamo. Its work perfectly in small model, but somehow when i apply for big project, Generic Model is created (I checked in Schedule) but cant select the created one in Revit??
In attached image, you can see the Generic Model doesnt Blue up.
Have anyone experience this problems before? hope to recieve your response.
I’m having the same problem. Did you manage to solve it?
I develop a Dynamo Graph to create a generic model using FamilyType.ByGeometry
and although I can select it in any view, I can’t do it in a 3D view, as you said.
However, I noticed that I can select this element in a 3D view, only when the view has a Section Box cutting through the element’s geometry.
Best to start a new topic with your graph, and image of the workspace, an rvt to run it on (or indication that it works in any template).
you’re right Jacob.
I just wanted to know if @soncongvu.nuce did find a solution.
However, my issue was indeed created by the 3D view visibility/graphics override.
No need for a new topic
