i’ve created view filter in Python Script, and want to immediately set override using Dynamo node instead of within Python Script, doesn’t work.
if i do it in 2 separate steps then it works, so i assume some kind of regeneration is needed for current Revit document.
I believe your issue is that you are parsing the filter before it is set, if you instead pass the filter you are creating in your python node instead, and get both view and filter from there i believe it would work
Change your last line to be
OUT = view, filter
And add a code block after your python script for splitting up the output in your view and your filter before passing to the last node
hi @Ning_Zhou,
The thing is you don’t need to use AddFilter Method. You can directly use SetFilterVisibility Method.
thanks Jonathan & Jean, i removed AddFilter method, changed OUT = filter, works now
Hi @Ning_Zhou
If a comment solved your problem, please mark that comment as the solution and help keeping the forum tidy, and maybe leave a like here and there
