Is possible to set the view range of view templates using schedule or similar?
i want to edit the top of the view range by unlimited for example, and in other cases leave it as level above with value -0.3 for example
Possible using revit API or Genius Loci package. Thread here showing how in its solution:
I mean modify the view template not the other views, if using view template the view range can be locked and not editable
This is a method of the view/viewplan class, which crosses over with view templates in the Revit API view class.Try sending through a view template and see what happens…
After getting to a computer and testing it looks like they do indeed return view ranges:
# Made by Gavin Crump
# Free for use
# BIM Guru, www.bimguru.com.au
# Boilerplate text
clr.AddReference("RevitAPI")
# Define list/unwrap list functions
def uwlist(input):
result = input if isinstance(input, list) else [input]
return UnwrapElement(result)
# Preparing input from dynamo to revit
uw_list = uwlist(IN[0])
view_ranges = []
for v in uw_list:
try:
vr = v.GetViewRange()
view_ranges.append(vr)
except:
view_ranges.append(None)
# Preparing output to Dynamo
OUT = view_ranges
You’ll find what you need in Genius Loci for get/set, but the API class you can use more specifically is here: PlanViewRange Class
you mean it works with a view template because is also a view? if that is the case cool! I will try. I just want to edit the view range by each view using schedule but it does not exist in revit schedule so I need the dynamo wizard
