I would like to set certain parameters for the View Range of specific views (ie Top Offset, Cut Plane, etc.). I know how to setup the views I want to collect and all that and I read through a post on retrieving the view range parameters but not setting them. Thus, I was wondering if anyone could help me figure out a way to set those parameters.
If using python, this is what I’d like to do:
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import ToDSType(bool) extension method
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
elements = []
for i in IN[0]:
elements.append(UnwrapElement(i))
for i in elements:
a=[]
a.append(elements[i].SetViewRange().SetOffset(PlanViewPlane.TopClipPlane))
OUT = [a]
ERROR 1: I don’t know much about .SetViewRange() and if this is the way to go.
ERROR 2: I want to make it so I can run it with multiple views and not just once. Hence, the for loops ,however, this portion of the code:
for i in elements:
a=[]
does not work. Any ideas?
Hi @Dynamonkey
here are some elements that can help you :
in order to use SetViewRange, you first need to get the viewrange of the view (GetViewRange) and set some of its parameters . Here is a code that sets the parameters of the top clipping plane and the bottom clipping p
1. Import RevitAPI, TransactionManager and DocumentManager
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import*
views = UnwrapElement(IN[0])
ltop = UnwrapElement(IN[1])
toffset = IN[2]
lbottom = UnwrapElement(IN[3])
boffset = IN[4]
count = 0
for v,lt,tof,lb,bof in zip(views,ltop,toffset,lbottom,boffset):
2. Getting the viewrange of the view
viewrange = v.GetViewRange()
3. Setting the parameters of the viewrange
* Setting level of topclip plane
viewrange.SetLevelId(PlanViewPlane.TopClipPlane,lt.Id)
* setting offset of top clip plane
viewrange.SetOffset(PlanViewPlane.TopClipPlane,tof)
* Setting level of bottom clip plane
viewrange.SetLevelId(PlanViewPlane.BottomClipPlane,lb.Id)
* setting offset of bottom clip plane
viewrange.SetOffset(PlanViewPlane.BottomClipPlane,bof)
* Applying the viewrange to the view
v.SetViewRange(viewrange)
count = count +1
OUT = '%d view ranges altered' %(count)
you can set the level and offset for :
I gave inputs for plane levels and offsets but these can be determined from the viewplans themselves…
Here’s an easier to copy paste version of the code
toffset = IN[2]
boffset = IN[4]
count = 0
#getting the viewrange of the view
#Setting top clip plane of the viewrange
# Setting level of topclip plane
# setting offset of top clip plane
#Setting bottom clip plane of the viewrange
# Setting level of bottom clip plane
# setting offset of bottom clip plane
#Applying the viewrange to the view
count = count +1
Thanks @Mostafa_El_Ayoubi this looks promising. I however cannot get it to run properly. To simplify I am only testing the top offset with 2 inputs.
IN[0] being a list of views and IN[1] being the top offset value which I’ve tried using a number slider, integer slider, string in all dimensional formats such as x’ x" but yet I get an error pointing to the for loop
which for this exercise I adjusted again only for top offset:
for v,tof in zip(views,toffset):
not sure if the for loop is the error but it points to that line and reads Typeerror: ___ not iterable
Perhaps there is a way to input the desired height offset properly.
Any thoughts?
If you want to use the same offset value for all view ranges , then you should only iterate through the list of views :
for v in views :
If you want a specific offset for each view than you must give the python node a list of offset values (same number of values as there are views)
Hello Mostafa,
I am trying to use your python script but there is a problem.
Any help would be really appreciated.
Since you’ve made a new post I’m going to close this (it’s over a year old anyway) and let the conversation continue there.
