Hi!
I need Dynamo to determine if a line is a straight line or an arc. The reason for this is that if the curve is a straight line, I need only to extract the start and end point, but if the curve is an arc, I want to extract either the arc center, radius and start/end points, or to divide the arc into, for instance, ten points along that arc.
I am aware that I could just divide all curves into a number of points, but this would result in way too many points in my final list of points.
Any help would be appreciated!
Best regards
Klaus
