Is it possible renumbering areas by spline?
Hi, everyone!
I would like to know if it is possible renumbering areas by spline, because I created a shared parameter to numbering stores/apartments, but I want automate this. I try to create a routine, but the node “Element.BoundingBox” isn’t work. Is it because areas are not 3D elements?
Hi @thur ,
Is there a specific reason you are turning your area into a Bounding Box?
You could also use the node Element.Geometry to get the area as Dynamo geometry.
Or another favourite node of mine from the Rhythm package:
I would also advise having a good read of the existing forum posts on renumbering elements by spline to see how others have gone about it. Foundationally the principles will be the same.
https://forum.dynamobim.com/search?q=renumber%20by%20spline
Hey guys, thanks for the tips.
I avoided using the Bounding Box like you said and I chose the Rhythm’s node Areas.Boundaries. Also, I changed my geometry scaling to normal and it’ was a success!
