Hi, I have a problem, you need list A which has two sub-lists A1-A2 with 6 sub-lists A1.1-A1.6, A2.1-2.6 to assign the parameters of another list B with two sub-lists. So that the sub-list B1 is assigned to all elements A1.1-A1.6, and B2 to all elements A2.1-A2.6.
I tried all the options of interlacing, nothing comes out, please help.
Sorry for my english.
Hi @stepao1414,
I didn’t fully understand what output you require.
But this is what I came up with from what I could understand.
Hope this helps.
Apparently I did not say correctly. Here is a screen attached, what is required to achieve. The first sublist with all his
sublists should have the same values (a, b, c, d,) the second sublist with all his sublists (e, f, g, h)
