Hi everyone,
I’m having a hard time trying to find a way to determine the points where some lines (3) intersect with the lines that form a square. Any hints ?
Dennis
Hi @d.kelfkens
Could you please post your end result screenshot. Thanks
Hi @Kulkul
I need to find the coordinates of the red cirkels
Is there a node for this? Or do I have to create a pyhton script to find these point ?
By the way, i need to find these points to be able to lengthen these lines to the lines of the square.
lol, thx
Thanks for your help !
I’m going to try your solution.
I started writing a python node for this. But if your way works that will be the best.
I cannot write code so I do my best with nodes.
I think this should do what you want.
Hi @Steven_Hansen,
Your solution works well but only if the lines are drawn from left to right.
My lines are drawn random (right to left / left to right) and I need all the intersection points with the square.
You think you can solve that too ?
Do you mean both ends to project?
Yes, both ends of the line have an intersection with the nearest line of the square
ok ya thats not a problem at all. give me a minute
This what I was looking for !
Thanks !!!
Thanks Glad I could help.
Change the lacing on Point.projection to longest. I think that should do it. Every thing else looked good
That was it !
Thanks again.
