hi, I am writing a script to read csv data point in xyz and create lines by data points in excel.
hi Frederic the explanation and the image shown below can’t explain what it actually means kindly elaborate on the question so that u get a better answer if u need to find the intersection between two lines go with Geometry does intersect node
thanks a lot, will try.
hi! im looking for the same kind of script… can you kindly post it here below?
Many thanks!!!
Looks like those lines don’t intersect, but I put this together.
intersect.dyn (23.8 KB) EXCEL DATA.xlsx (8.7 KB)
