Intersection between a surface and panes
Morning all,
i have a surface imported as SAT in Rhino that i want to intersect with a series of planes
When i use Geometry.Intersect i only get partial results (meaning not all planes finds an intersection)
Using Surface.ProjectInputOnto (with Lines) i get the same result
Any idea why and how to fix it is welcome :slight_smile:Cheers
Can you share the sat and the dyn?
The DYN yes, the SAT complicated since it’s still not a public project :frowning:
Have you tried intersecting with big enough rectangles rather than planes ?
I tried with lines also, same result and EXACT same intersection so it’s not random
Strange indeed…
If it is only about getting isocurves, I think Curve.ByIsoCurveOnSurface might work.
The only time I had a problem with intersections was when the surfaces I wanted to intersect where too big.
Different issue with iso curves. they don’t seem to respect the surface
And here’s what i get when i intersect the isolines with the surface
Quite weird that some isocurves seem to stop at the end of the surface whereas other seem to ignore the boundary…
Quick thought : Maybe your initial Surface is not correctly defined / imported and there are some “leftovers” points that we cannot see. Does the first intersection you made in your initial post contains any point ? If yes, could you highlight them ?
Does this happen with any other Surface ?
One more clue, here’s the Reference Planes with a solid generated from the same surface in Rhino
Same Surface, split in 3 using ACIS 2,3 and 4
Im loosing my mind ahahahahah
Hi Daniel. Why don´t you try with a simpler surface, just to discard an issue with its geometric definition (It happened to me once).
I’m not sure if this might help, but I usually export the Rhyno surface in a 3dm format when I need to create it in Revit.
One more test :slight_smile:
Inserted the thickened surface then exploded it then…
Im getting more lines but still not what i need :slight_smile:
Seems ok with a quick made up shape so it confirms that it’s on the Rhino side i guess.
If you can share the sat via PM or other non-public channels I’ll try and see if it’s a geometry conversion issue. Would only need that one surface.
This should work …
sat.dyn (16.1 KB)
Have you tried adjusting the geometry range in dynamo or scaling the geometry?
I ended up creating large circles and transform them into surface to cut
@Daniel_Hurtubise
Maybe this will work too
get points from SAT and intersect.dyn (20.1 KB)
Hello, I have a similar problem and my surface is a very simple square face. Is this a problem because of Revit?
