I am trying to count how many walls intersect but that arent split and therefore dont have a set joint type (miter etc…) and also a angle between the intersecting walls, the angle doesnt matter i just need to determine if the walls are at 90 degrees or not.
Not sure that I explaned my self very well in my first.
Effectivley i am after two outputs:
how many tims does a wall intersect another wall all the way through?
what is the angle are the walls at? the reason for this is if it is at 90 degrees it is called a plain joint and anything else is and iregular joint. i am trying to determine how many ‘plain joints’ and 'Iregular joints ’ are in my model.
Following my previous post i have been able to export the co ordinates at the start and end of a wall, find if any of them match and if they do work out the angle between the two vectors…
however i can’t work out how to export the co ordinates of where an intersection occours on a wall when it isnt at the end see image below as an example…
