I’ve been trying to get the profile label anchor and location information in a profile view using Python in Civil 3D Dynamo.
I first get the label group object, and then for each LabelGroupSubEntity I use sub_entity.LabelLocation
or sub_entity.DimensionAnchorInfo.Location
to get the location and anchor info, this works fine when all the labels are in the same profile view. But when I created sheets, the BVC and EVC and PVI may be in different views, and in this case, when I try to get the location info, it always gives me an internal error. Is there a way to get the location in this case?
editor = adoc.Editor
doc = CivilApplication.ActiveDocument
with adoc.LockDocument():
with adoc.Database as db:
# Place your code below
# get the alignment and profile and profile view
# there is only one alignment in the drawing
# the profile view I'm having trouble with is index 6
alignment_id = doc.GetAlignmentIds()[0]
alignment = t.GetObject(alignment_id, OpenMode.ForRead, True)
profile_view_id = alignment.GetProfileViewIds()[6]
profile_view = t.GetObject(profile_view_id, OpenMode.ForRead, True)
# FG profile index is 1
profile_id = alignment.GetProfileIds()[1]
profile = t.GetObject(profile_id, OpenMode.ForRead, True)
# get all the label groups
# https://help.autodesk.com/view/CIV3D/2021/ENU/?guid=ef8424ec-f759-4826-8a86-1b97eabf710c
label_groups = ProfileCrestCurveLabelGroup.GetAvailableLabelGroupIds(profile_view_id, profile_id)
for label_group_id in label_groups:
label_group = t.GetObject(label_group_id, OpenMode.ForWrite, True)
# get the sub-entities (the individual labels in each label group)
# https://help.autodesk.com/view/CIV3D/2021/ENU/?guid=9078bd07-1e44-3eed-b744-381d1602f534
for sub_entity in label_group.SubEntities:
sub_entity_xy = sub_entity.LabelLocation
Profile View Number 6 is the one I’m having trouble getting the label location, as you can see, the labels are separated into 2 profile views. But I don’t have a problem with the one left on view 7, because the PVI is left in the same view.
