What am i doing wrong here? Any Help
Interference Check May 25.dyn (185.4 KB)
Hi @Sujan
Can you please try and isolate the cause of the problem by unconnecting the inputs to the Element.IntersectsElement node. Run it, does the exception occur? If it works then slowly reconnect each node upstream so you can identify which node is causing the problem. If the exception still occurs, then copy your graph and remove all nodes apart from the LinkElement nodes for STR link model and repeat for ARCH model. I think you get the idea. Please perform this exercise and start a new post once you work out where the problem is coming from.
Edit: Also, why are you attempting to clash title blocks, filled regions, plan regions and other annotation elements with 3D building elements?? It should be pretty obvious why you might experience exceptions when the nature of your clash test is flawed. Rectify the obvious before attempting to isolate the problem!
Answer to your questions:
I’m not experiencing the issue. Only problem are you Set Parameter nodes - check those parameter names exist:
(@Kulkul - I hope you are well; I think its best if @Sujan thread is split into a new post. Thanks!)
