Insert pipe sleeve at wall intersection with rotation and size
Thank you everyone for pointing me in the right direction! I was finally able to finish it up with your suggestions.
I ended up using the following packages:
Archi-lab Grimshaw
Clockwork
Bakery
and I think I have something from Springs
So, here’s what it does:
  1. Automatically find 1 and 2 hour fire rated walls in a linked model.
  2. Select all horizontal pipes in the current model.
  3. Clash for insertion point and filter out any pipes that do not intersect.
  4. Insert a pipe sleeve at clash point.
  5. Set rotation of sleeve to match pipe.
  6. Set diameter of sleeve to outside diameter of pipe.
  7. Set sleeve length equal to wall thickness.
