Insert members of one sublist into another sublist (list levels problem, help)
I have a list of sublists with differing numbers of members. I want to insert a varying number of members to the beginning of each sublist. So I have my two lists of sublists, and I want to combine them on the level of sublists, but I can’t get the list levels worked out.
Given [ {a,b,c} , {d,e,f,g} ] and [ {1,1,1} , {1, 1) ]
I want [ {1,1,1,a,b,c} , {1,1,d,e,f,g}
Here’s the closest I’ve gotten:
It’s almost right, but it’s inserting a list at the beginning of each list instead of the actual members. I’ve been messing around with list levels and I can’t figure it out, can someone point me in the right direction?
You can try like this.
robert12546358:
Thanks for the quick reply. I’m trying to get the lists on the same level of output, i.e.:
[ {1,1,1,a,b,c} , {1,1,d,e,f,g} ]
Rather than having mixed levels, if that makes sense
jbo, that’s what i have in mind, does it work if the second list is also sublists? When I try it with sublists I get mixed levels similar to robert12546358:
see image
Can you share your file??
Got it. So obvious once you see the right answer :roll_eyes:
Thanks for the help!
If a comment solved your problem, mark it as solution
