Insert Legends by template not by co-ordinates
Hi all,
I’m trying to create a script that copies the all the schedules from a template sheet then places them in the identical location on other sheets.
I’ve started by trying to modify Daniel_Woodcock1 's insert legend placer and inserting a python script that Konrad has done in a previous post.
But I get this error, excuse my lack of knowledge when it comes to the API and python. Complete novice in that regard.
schedules on sheet test.dyn (25.1 KB)
Regards
Hi @James_Washbourne,
With a quick glance I can see you are trying to place ScheduleSheetInstances (sort of like a viewport for schedules which is a visual representation of the view on sheet and not the actual view (if that makes any sense at all). This is not allowed I’m afraid as the node takes a ScheduleView only, however, you can get the ScheduleView from this and is done like so…
The GetOwnerViewSchedule (Py) node has the following code…
doc =  DocumentManager.Instance.CurrentDBDocument
clr.AddReference("RevitAPI")
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
schShtInsts = tolist(UnwrapElement(IN[0]))
outList = []
for ssi in schShtInsts:
	outList.append(doc.GetElement(ssi.ScheduleId))
OUT = outList
And you should place it about here…
I think this should work. Let me know how it goes!
Cheers,
Dan
Hi Daniel,
I’ve had to do a unit conversion but works like a dream. So that’s sorted. Thank you very much.
Second question, is there a way of filtering the views from the springs.Sheet.Views+ by type. So I get a list saying whether is a floor plan or 3d view etc. I’ve tried the Element.get parameterValueByName node, but its not giving me the results I’m after.
filter
Thank you
@James_Washbourne you need to mark the solution given by @Daniel_Woodcock1 and create a new topic for your second query. We can’t have many solutions in one topic. Thanks!
Kulkul,
Done thank you
i have a problem with the location of the schedules they go so far at the new sheet … any help
Hi @ae19891989, I’m not sure what you mean. Can you please show an example or graph or any errors you are getting.
I also have some new code for legend/schedule copying in the link below…
