Insert image in AutoCAD or Civil 3D without external reference, is it possible? Help, I have 1000 images
How do you meen insert? With link, in dwgfile as raster image or as object?
One question that come up in my mind is, why do it with Dynamo? Can’t you use standard function and still save time?
OLE format, each image has coordinates. What would be the standard option, which adds 1000 images with coordinates without a link. Thank you
Oki, I see. No, then I don’t know. Didn’t understood that you where asking about OLE images.
Wonder, why didn’t you pinged you previous post about the same topic which I found when I started to search for info?
KR
Patrick
I found this, but I don’t understand python
open the image in Paint or any other image editing software,
Press CTRL+A to select all, CTRL+C to copy, and paste in AutoCAD (CTRL+V)
That doesn’t work for me for multiple images ![]()
It’s more like an Autolisp related issue than Dynamo…
Can someone help me, what is the error?
import sys
import os
# Add Assemblies for AutoCAD
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('Autodesk.AutoCAD.Interop')
from Autodesk.AutoCAD.Interop import *
# Remove conflicting method
del globals()["Image"]
# Add Assemblies for Windows
clr.AddReference("System.Windows.Forms")
clr.AddReference("System.Drawing")
# Import references from Windows
from System.Windows.Forms import Clipboard
from System.Drawing import Image
output = []
for raster in IN[0]:
imgpath = raster[0]
if isinstance(imgpath, str) and os.path.isfile(imgpath):
img = Image.FromFile(imgpath)
Clipboard.Clear()
Clipboard.SetImage(img)
if Clipboard.ContainsImage():
origin = raster[3]
comstr = "_.PASTECLIP\n" + str(origin.X) + "," + str(origin.Y) + "\n"
adoc.SendStringToExecute(comstr, True, False, True)
output.append([True, raster[3:]])
output.append([False])
OUT = output
You tell us?
