I’m trying to automate detail sheet creation using Dynamo. Typically, we create detail sheets by creating a layout and attaching the pdf as an xref. Is there a way to attach an image/pdf to a layout with Dynamo?
I don’t know if this helps or if this is working with image/pdf, but I created it for attaching dwg xref on multiple layouts. Pardon me for the script being a bit messy, I didn’t have time to polish. Look for the python script. I’m not sure but this may be achievable with packages since then. (Arkance, Camber, C3D Toolkit)
pecsét.dyn (138.9 KB)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
def add_xref(path,blockName,switch,x,y,n):
global adoc
with adoc.LockDocument():
with adoc.Database as db:
# Determine whether to overlay or attach
if switch==True:
oid = db.OverlayXref(path, blockName)
oid = db.AttachXref(path, blockName)
if not oid.IsNull:
for i in range (0,n):
insPt = Point3d(x[i], -5, 0)
# Create block reference
blkRef = BlockReference(insPt,oid)
# Add block table record
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[y[i]], OpenMode.ForWrite)
btr.AppendEntity(blkRef);
t.AddNewlyCreatedDBObject(blkRef, True)
t.Commit()
return x
OUT = add_xref(IN[0],IN[1],IN[2],IN[3],IN[4],IN[5])
The Arkance Systems Node Library contains a node to add an Image Reference, also possible on a Layout.
