Hi. Am i having wrong versions of something? I m not getting inputs in the player versions.
Also outputs adding isnt ideal
Hi @ahuygen ,
Hard to help without seeing your graph but it might have to do with that you have to rename the input and output nodes to see them in the player.
Add a watch node to the canvas and mark it as an output. This is a known bug which has been addressed in a future build.
thankyou everyone. it helps
a different issue i have is. The editor graph works but the player version , gives an error; ‘input outside modeling range’
Sounds like an unrelated issue. Please mark whichever of these fixed the problem and start a new topic, including a sample dwg and your current dyn so others can reproduce.
allright
