Information flow speed
(I have to activate/deactivate the node point wire to have an adequate positioning)
Information come too fast. Level in 1st and point in 2nd, right?
thanks in advance
cordially
christian.stan
I’m guessing you’re running in Automatic and the nodes aren’t reevaluating. Run in Manual mode instead or close and reopen to “refresh” nodes.
Dynamo executes all nodes at once (more or less). If your graph is in Automatic mode it will only reevaluate if the data has changed. Your graph may not be recognizing the change in data necessary to rerun the node. Disconnecting and reconnecting both force reruns.
I have beginner’s syndrome
(Keep it on automatic, even though I’ve had setbacks before, I have to break this bad habit, time will pass)
Thank you for the precise and targeted explanations (You had correctly identified)
However, in manual mode, I have to delete the families in the event of a family change on the 2nd run (or save the script without deletion)
No problem with the dynamoplayer
Cordially
christian.stan
