We have been facing few issues regarding Bounding Box for Structural framing elements as described below.
Generally, we place Structural Framing Elements Either Parallel to X-axis (or) parallel to Y-axis in over 80% of our Projects (let this be case 1), but in 20% of our projects we will be having Structural Framing elements in Inclined manner (this will be called case 2). This inclination will be mostly present in X-axis and Y-axis but in few locations it may be present Z Axis also (i.e., the height of element can change).
Usually we need to check clash detection or overlapping elements between all these Structural Framing Elements.
So we have been using Bounding Box for this overlapping check between all these structural framing elements in Dynamo.
But we observed that Bounding box for structural framing elements which are parallel to X-axis or Y-axis (case 1 explained above) in the node are been achieved exactly as needed in the Dynamo.
Where as, for inclined Structural Framing Elements the Bounding box is not been achieved exactly as needed in the Dynamo in the inclined manner.
What we need is a Bounding box for inclined element as shown in BLUE, but what we are achieving is as shown RED in Attached Image.
So, Please Confirm if any method or Process is there in Dynamo to achieve the Inclined Element Bounding Box as needed.
Your help will be Greatly Appreciated as we will behaving 1000s of elements in each plan for us to check overlap between these types but similarly sized Elements.
