ImportError: No module named RevitServices
hello everyone,when i improt the RevitServices module,i get a error like this:
error1
i’m sure that i have the dll file in my disk:
C:\Program Files\Dynamo\Dynamo Revit\2\Revit_2018\RevitServices.dll
and this my python code:
Import ProtoGeo
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import DocumentManager and TransactionManager
Import ToDSType(bool) extension method
app = DocumentManager.Instance.CurrentUIApplication.Application
#room list
roomElements = UnwrapElement(IN[0])
#Variables for collecting list
roomElems =
roomLocations =
roomNumbers =
roomNone =
for item in roomElements:
if area is placed then get stuff
if item.Area > 0:
    location = item.Location.Point.ToPoint()
    # assign your stuff to lists
    roomElems.append(item)
    roomNumbers.append(item.Number)
    roomLocations.append(location)
        roomNone.append("Rooms not Placed")
List your stuff to the OUT variablez
OUT = roomElems, roomNumbers, roomLocations
i don’t know how to solve this issue,and i hope to get some help,thanks very much:smiley:
I met the same problem. Have you found any solutions
可能是插件引起的,在导入是添加路径就可以了。代码如下:
import sys
sys.path.append(r’C:\Program Files\Dynamo\Dynamo Revit\2\Revit_2019’)
clr.AddReference(‘RevitServices.dll’)
Watch the double vs single quotes and make sure the quotes are correct if your copying and pasting from the web.
https://primer.dynamobim.org/10_Custom-Nodes/10-6_Python-Templates.html
It fixed my problem.Thanks
