Import Error:No module named Revitservices again
Hi everyone,
I am following ArchSmarters python code to create Placeholder Sheets. I am getting the error as seen in the pic below.
I don’t think it’s the code. I think it has something to do with the RevitServices.dll file and/or its location. If I have made a mistake with the code, please direct me. I followed it from this video. https://www.youtube.com/watch?v=LPk0LMjsyy8
Where should the RevitServices.dll file be located? I am on a work computer and thought it may need to be in the “Users” folder but not sure.
I am in Revit 2023 with Dynamo V2.16.4
Below is my script.
import sys
clr.AddReference('RevitAPI')
from RevitServices.Transaction import TransactionManager
from Autodesk.Revit.DB import BuiltInCategory, FilteredElementCollector, ViewSheet, Transaction
sheetNumbers = IN[0]
sheetNames = IN[1]
# Get the current Revit document
# Start a transaction
t = Transaction(doc, "Create Placeholder Sheets")
t.Start()
# Create the specified number of placeholder sheets
placeholderSheets = []
for i in range(len(sheetNumbers)):
    sheet = ViewSheet.CreatePlaceholder(doc)
    sheet.Name = sheetNames[i]
    sheet.SheetNumber = sheetNumbers[i]
    placeholderSheets.append(sheet)
 # Commit transaction
t.Commit()
OUT = placeholderSheets
Cheers and thank you!
Try using import RevitServices after you add the reference.
Is this where you would place it? I’m still getting the error.
Check my boilerplate here. I use this in most nodes.
Line 23-26 show how to set up revitservices.
add a “s” at RevitServices.Transactions
Thank you for your reply Gavin and the boilerplate code! I’m going to stick it in my code to learn from it and mess around with it. I love your vids BTW.
That was it! I was able to take out the “import RevitServices” line as per Nicks post. Thank you all for your help. I looked over the code so many times my eyes were blind to that one mistake. haha. Not even AI could pick up on the mistake.
