Imported Direct Shape elements can not be selected
Hello dear professionals.
Could you please advise why dynamo can not select the elements imported from an IFC file which was exported from Tekla and how I can select them ? Those are direct shapes elements. It gives this error:
The type initializer for ‘Revit.Elements.DirectShape’ threw an exception.
(Revit 2017)
Elements.rvt (436 KB)
Hello @m.shcheblykin
which version of Dynamo are you using?
Results with Revit 2018 and Dynamo 2.0.4
I just had rechecked the attached file and I found that the issue is not there any more. Looks like the issues exist only in the project revit file. This is a very weird situation. I think that reimporting of D shape elements can fix the problem. thanks for your reply
