Good morning forum, these days I created a routine in dynamo for civil 3d (pipe network) in which, through an excel sheet, I changed the invert elevation of all the pipes that I had in the model, relating their name and their initial elevation and their final elevation, I developed this with the toolkit tools and its key node for this was the (pipe.setinverts) the problem is that the toolkit tool does not have a node with (pipe.setobvert) and I do not know how to create that node or how supplant its function, I add an image of the one I already have with the inverts, in case anyone knows, thanks for your help
You could compute the invert elevation by subtracting the pipe inner diameter from the crown elevation and then set the invert accordingly.
if the problem is that we have a list with the obvert/crown elevation and the diameter we have is the commercial one that is a little different from the real one, so if we would need to apply it with the obvert elevation and not with the invert
