Hi all,
I have been having problem using the ImportInstance.ByGeometries node.
I am trying to create a tool that will help me visualize the location of certain elements in my Revit model using Dynamo. I have retrieved these elements (lines) and have created a solid in Dynamo to capture there location visually (in my Revit model). Interestingly enough when I run the script while having an active window screening a Revit Sheet the node does not work. On any other active window screening a regular view (3D, floor plans, structural views, etc.) the node works.
Is there a way to make the node work while keeping my pre-designed sheet open in Revit ?
Thanks in advance for your help,
Thomas Trinelle
